Brian peter
Good morning everyone can you please help I have a 1993 ducato campervan with a 1.9 TD the start okay but you have to do the heater plugs three times but then it starts on the first turn of the key blue smoke for about a minute and then all it's clear and will happily rev and rev out on the road drives fairly well not fast but then they never were problem is I get a lot of engine vibration and the gear state is trying to shake itself out when engines on the load going up hill it will clear by going down a gear and using lots of revs had the engine and gearbox mounting changed that didn't make a difference no leaks in the fuel lines although I had three to sort out no overheating issues only happens when going uphill under load going downhill is fine should I even do 70 mile an hour and put in the clutch in when they have lots of engine Judah she just goes back to taking over fine help any ideas
