Every time I remove the spark-plugs on my 1992 750 fire engine they're covered in white deposits.
I believe this means that the engine is running too lean.
The engine runs badly untill it is fully warmed up.
Looking at the emissions test from the last 2 MOT's the CO reading has been in the region of 0.1%-0.2% CO.
I believe the recommended setting is 1.5% CO? Can someone confirm this?
I have connected a gas tester to the exhaust pipe and tried turning the mixture screw a couple of turns but there was almost no change in the CO reading.
Is there something else I should be doing to adjust the mixture?
Am I right in thinking that anti-clockwise makes it richer?
Many thanks and any ideas would be appreciated.
