You think it is camshaft or crankshaft sensor? Or do I need to use Mes software for phonic wheel and self adaptation procedures? I don't have Obd device for mes i have one which is not compatible with the mes programme. I cannot connect to my computer using that obd device. If you think it is the Mes software which will solve the issue with phonic wheel and self adaptation, i will buy a device compatible with the car to use MultiEcuScan.Hi
Did it have a cam timing belt recently ?
This commonly happens after a belt change as the signals of
Camshaft and Crankshaft sensors become
Mis.aligned
Random misfire codes, p0301 p0302 p0300 changed spark plugs two times coil and spark cables
Dude thx. Can I have a chance without the Mes software. İ wonder if i Can I do that manuallyHave a read..
https://www.fiatforum.com/grande-pu...ent-light-no-issue-2.html?297808=#post4273620
Then let us know your thoughts![]()
Did you ever do the phoenic wheel reset?
