FatNote
Greetings all!
I think have some injection problem with my '92 Lancia Y10 which I understand has the same engine as the Panda. Maybe someone can help me? [?]
Symptoms: the engine runs fine if I don't give 'er gas... but then as I begin to depress the accelerator there comes a point where the engine starts to 'choke up' and black smoke comes billowing out the exhaust. At higher throttle it clears up and seems fine. Also, sometimes when the engine is cold the problem completely disappears!
I've been driving this car for two years now and I love her!
A free-bee from my brother, she was my transport and home during an 8-month sojourn through Europe... she survived the road through an Italy-Germany-Austria-Croatia-Italy-Scandanavia-Switzerland loop of 20000kms without even once letting me down. But for the last year or so, she's been developing this problem. As I'm naturally lazy I haven't bothered to do much about it and initally it only appeared when in 5th gear after long highway burns. But slowly the problem has increased, until now I basically have a digital car: no gas ok, or full gas ok!!! :I
So, with some advice (and spare parts) from a friendly Italian father-in-law, I dismounted the distributor module. I found the vacuum advance diaphram was ripped to shreads, and a small contact to the inner wall of the module on the piece that holds the Hall effect sensor was broken. Replaced both from extra parts but that didn't make any difference.
Around this time I discovered that the problem seemed to be coming from the injector... when it started choking I observed that the injector seemed to be over-spraying (explain the black smoke and the fact that I'm spending a lot of money on gas lately!!!). That got me researching injection systems and made me think to check what I think is the O2 sensor (stuck in the exhaust manifold). Pulled it out and sure enough it was covered in black gunk! Replaced it with a cleaner looking one (thanks again to Super Mario in Italy!) and that seemed to fix the problem... FOR ONLY ABOUT 2 DAYS!!!!
Then the same old problem again!!!
So, now I'm wondering whether to bite the bullet and take her in to the FIAT dealer... but I thought I'd just ask you guys if you have any suggestions?? Presuming I find the problem (could it be the MAP sensor? Faulty electronics on the distributor?? Gunk in the fuel pump or low fuel pressure???) I think it would be very wise that I set precisely the timing and reset the computer according to the instructions posted here (thanks John H!!
Ok! Looking forward to any help!!!
