Technical marea center console
Cornwall
Hi, I'm in the middle of putting a marea center console in my bravo hgt but the rear backer has no where to screw in! I looked at serval threads and can't seen it find anyone who's done it other than leaving it out! I've tried that but seems to be rather wobbly!
Centre console comes with support attachments for front and rear, on front you use the original bravo ones as there is no channel for feet like in marea. In the back you use the one from marea.
On mk1 models the "nuts" are missing from the floorpan so you need to install them to put the attachment screws in. Then put the modified air duct in and finally the console and screw them into place.
Before install you should have the console itself with the gear lever+boot. The main air duct and two for the feet (you modify these into one part to work on bravo). And the support plastic pieces where the console screws into.
I think this image has some extra parts but it shows them.
Thanks for the reply, I've got everything in the picture and modified the air duct! I've got a bravo 155 aswell so I could have a look to see exactly where there positioned and mimic it.
