Hi, bought a fiat panda, 2006, 1k miles, only 1 key......which Ive lost. Fiat have quoted me about £1000 to get it running again. I think I may have to scrap the car, as £1000 for a key/ecu is ludicrous. Is there anything else I can do?
Ive found a company selling blank panda transponder keys for £10.....can I get it cut by taking out a door barrel or something and taking it to a locksmith?
NO....go to your dealer (or any infact) you will need proof of ownership & I.D.
Parts dept will order a key from your chassis number (this is how keys are ordered!) which will take 2-3 days. This can open your car but not start it so it will need to be programmed by dealer.
If they say no then show them this post or even get them to PM me!!!
hi, are you saying that I should not need to change all the ecu, locks etc a the dealer should be able to supply and code a new key?
Its a code 2 immobiliser system (rolling code) same as mk2 punto & I have programmed loads this way.
Another point is you can programme only one key (garage might tell you otherwise) however in light of recent events your best getting 2
2 non-remote keys (£40 each) £80
examiner programming £40
(possible keycode/ISR charge) £10
£130 (better than £1000)
hi, wheres the cheapest dealer for the keys as I cant find them for less than about £100 each?
I have some questions, but surely the cheapest way is ordering a key from the dealer.
1. If you need a code then why do Fiat supply a plain key as a spare with no electronics attached to it.
2. When I enquired that they failed to supply me with the sequence and code card, which the fiat manual suggest it is kept in the car!! to access and start the car my dealer said this function is not fitted to UK cars.
3. If the battery fails in the main key how is it reprogrammed surely not by the dealer at great expense - there must a way to re-sync with the car when you've replaced the battery?
As above, Panda is a code 2 system. The dealer needs the V5/I.D then they will order a key for the car. Once this arrives it will unlock the car but not start it untill programmed.
All this talk of £1k is crap and its worrying people are quoting such figures?
