Modano
Hi Tipo enthusiasts.
The Tipo I've given to my mother has undergone the french MOT ("Contrôle Technique") and failed at the emissions tests.
French tests for such old cars (1994 - 1.6ie) are rather permissive, and it never failed for the past 5 or 6 exams.
The Tipo has 220 000 kms.
I have a Multi ECU Scan program and probed the ECU which indicates a permanent Open Loop on the lambda probe, stuck at 4.58 V, flat. Even after a 10 minutes run, still flat, no signal at all. I unplugged/replugged the wires, without success.
First, am I guessing right the ECU has no signal from the Lambda probe and goes in a alternate law that is emitting much more, only depending on throttle/temp/revs parameters , with a richer mixture ?
Then, how would you suggest (of course excluding trying a new one
) that it isn't the Connector to ECU wiring that is cut rather than a totally failed lambda probe ?
Then, other than this, what lever may I have to reduce emissions ? I was rather thinking that this ECU is all integrated with no setting whatsoever.
Also, I need to check the report, although I'm pretty sure it is a CO over emission, but can this be related to the catalytic converter ?
Thanks a lot
Thanks a lot
