Knocking noise while turning
Hello all I have a fiat marea 2001 elx auto and last month it developed a knocking noise when turn left or right and while stationary turn the wheel left to right and it knocks. I've replaced droplinks already
Hi.
Quite possibly ii its the bearing on top of front shock..
it gets sticky.. and holds top of spring tight
As you steer.. the bottom of spring twists
Itll only twist a little then pushes the top bearing round.. often with a BOING from the spring
Common issue on later puntos :eek:
Mareas.. I had 2 jtd weekends.. :)
Charlie
Hi.
Charlie
are they easy to fix bud
Cool man hey Thank you so much for the information buddy I can't thank you enough. I also suspected the lower balljoint on the wish bone or the driveshaft as they can pull when turning if they naff. This car has had me scratching my head for weeks lmao
