Jump starters and jump starting.
Edinburgh Scotland
Just had to jump start my pal's car again - I'm pretty sure he's got a parasitic drain problem but it's a big, fairly modern, luxury make and he doesn't want me "messing" with it. That's Ok by me - if I get something wrong it could end up with a very big bill! but he needs to see an auto electrician or competent dealer. So I was sitting on my garden bench this afternoon in the lovely warm sunshine, just like yesterday, which has been the first time it's been realistic this year without freezing, and I got to thinking that I've done a number of jump starts for family, friends and neighbours this winter - more than usual it seems to me? My perception is that modern cars with their EFB batteries seem to suffer more failures than the old cars with normal flooded batteries? Also, these EFB batteries seem to "fall off the cliff edge" to a far greater extent than the old type batteries?
So, having had that thought, I was then thinking "I'm finding it hard to lug my jump batteries around these days". As I've mentioned before, I have a medium sized battery out of my boy's Punto and a much bigger one taken from my SEAT Cordoba 1.9 diesel when I scrapped her. The Cordoba battery is a 77Ah jobbie and not something you can carry very far. On the other hand it packs quite a punch and has no problem cranking larger cars like my friend's. Trouble is he lives in the next street so I don't want to start my car just to run it for 5 minutes so I carry the battery round to his, but I'm pretty much done by the time I get there - he carried it back by the way. So I need a lighter solution and, ideally, something which can live in the car all the time. - It's not really a good idea to be carrying a large lead acid battery around in the boot all the time "just in case"!
So, I'm thinking again (I've mentioned these in the past) about a jump pack. What comes to mind at first is a battery based pack. These come in all sorts of sizes with traditional lead acid or Li Ion and other types of battery. They all have one particular problem, You've got to remember to keep them charged! There's also the problem that the batteries degrade with time and there are many reports of them becoming reduced in capacity and next to useless within around 3 to 4 years of purchase - I think the hybrid batteries last longer than the traditional lead acid type but they're all unusable if you don't keep them charged.
With all this in mind I've been looking at ultra (some call them "super") capacitor devices which are carried discharged and charged up over just a few minutes using what little charge is left in your vehicle battery (or the battery in another vehicle). These devices are a relatively new arrival on the motoring "scene" and I've been contacting manufacturers and retailers for information as well as scouring the internet more generally. These are pretty clever devices so here's what I understand about them so far. The pack itself contains no battery in the traditional sense (although there are hybrid devices which contain a small battery specifically to charge the capacitors. However they still have the problem that they require regular charging) So, the type which attracts me most contains a bank of five or six Ultra capacitors controlled by some smart electronics. They have two main leads with battery clamps - just like jump leads - which clamp to the car's battery (red to positive and black to negative). Next thing to understand is that most "flat batteries" are not in fact "flat" but just discharged to the point where they don't have enough oomph to turn the engine over - typically around 10 to 11 volts. So there's actually a lot of electricity still available in that battery, just not enough to crank the engine - starter motors need a lot of current. Now, from what I've understood so far, each capacitor is rated at 2.7 volts so, when first connected to the vehicle battery, the "clever" electronics connects the capacitors in parallel. Now with each capacitor rated at 2.7 volts they will very happily charge up fully under the influence of the voltage still available in the battery. Most seem to take about 5 minutes to fully charge but it varies. Then, when fully charged the electronics connect the capacitors in series so that's going to be 13.5 volts for the string of 5 capacitors and 16.2 for the units which use 6 caps. (in practice the six string devices are limited to 15 volts by the electronics) which gives plenty of current to turn the engine over for long enough for it to start - as long as there's not some other technical or mechanical reason why it's not starting in the first place. If the vehicle battery is under about 5 volts then you're stuffed because it can't charge the caps with this low a supply voltage. However most of the time it's going to work as battery voltage is not that low very often unless the vehicle has been left standing for a very long time - and maybe, in that case, a new battery is going to be the best option anyway as it's going to be needed due to the original battery being sulphated.
Here's an add for one of the more popular units available in the UK:
There are others if you look. Autowit is a popular one in the US which sometimes turns up over here too:
I thought I'd finish by saying, in my experience, as long as you are very careful about making your connections correctly ie, positive on jump pack/slave battery to positive on vehicle battery and neg to neg - I always connect the negative to chassis/engine block not directly to battery terminals as is now recommended by most manufacturers, then you're unlikely to have problems - but not guaranteed to be "safe" so you just need to be aware there's always a risk when jump staring of doing serious and expensive damage, especially if you're inexperienced - for instance connecting a well charged slave battery to a mostly discharged vehicle battery will likely produce a spark due to the difference in potential voltage between the two, so always make your final earth connection to the engine block or chassis earth well away from the battery. Most risky of all is to do it the "traditional way" by which I mean car to car using jump leads. Connecting the battery from one car to another in the "traditional" way is effectively connecting together the electronics in one vehicle to the other and they may not be compatible so is very risky. If you really have to do it then make sure the car's bodywork is not touching the other vehicle and DO NOT RUN BOTH CAR ENGINES AT THE SAME TIME. So, if you really must, with both engines off, connect the jump leads up pos on donor car to pos on flat battery then neg on donor to neg (chassis/engine casting) on flat car and try starting the flat car. On no account even turn the key in the donor vehicle and certainly don't run it's engine. With both batteries connected and both engines running the ecu's controlling the charging current in either/both vehicles can become "confused" and may spike the supply voltage thus ruining electronic control units - and that can be hideously expensive. I just don't do it. Either use a jump pack or, like I have been doing for years, use a slave battery. Even then you need to be very careful to make good and correct connections. Just remember batteries produce highly flamable hydrogen and oxygen gasses when working and they will produce it in quite large quantities when they've been working hard, as they will when trying to start an engine. So sparks from making connections are always unwelcome and you can make sparking worse by being "silly" when making connections. Jump packs are pretty good in this respect because they usually require you to press a button before heavy current can be passed. It's also worth mentioning that some vehicles, Honda was always a favourite, are very sensitive to messing about with their batteries and can lock you out of the ignition inhibitor if the key is left in the ignition when a battery is disconnected - and expensive dealer visit will be needed to recode the key. So, unless you need to run the vehicle engine I'd always keep any key well away from the donor car when trying to start the vehicle with the flat battery.
So, with all this in mind, I'll say again that I just don't do car to car jumping any more and I'd advise you not to either. Using a slave battery has many attractions because a slave will give you a good long, or multiple short, periods of cranking - but you need to be very careful connecting your cables because of the risk of sparks. All in all a jump pack is probably the safest and very convenient for keeping in the vehicle but, if battery powered needs to be charged from time to time. I've made up my mind I'm going to go with a capacitor type jump starter and I'm in the final stages of deciding which one to opt for. Should be able to confirm my choice this coming week.
I'll just finish by saying again that messing about attempting a jump start is not a very safe activity, especially for the inexperienced. The things I've talked about above have worked for me but may not for you so if you give it a go and it all goes pear shaped don't say I didn't warn you to leave well alone.
Or a small sack trolley for the battery you have?
Absolutely. I actually have a home made one which works well for most purposes. However, being home made, I used some old and quite small diameter solid rubber wheels. Because they are small diameter and solid they transmit every tiny irregularity in the road/pavement surface through to the load being carried. Unfortunately this means the load tends to move around and can easily fall off. Mostly this is of no consequence as I just use a couple of bungees to restrain the load. However I do worry a bit about transmitted shock causing damage to battery casings and maybe loosening some of the lead paste from the plate matrix. On the other hand it's probably helping stop electrolyte stratification?
You've made me think now and I think I remember putting some protective package insulation away on one of the shelves in the garage. Maybe I could adapt it in some way to fit the sack barrow for when I'm using it to carry the battery? On the other hand, I do this pretty infrequently so maybe I should just make whoever I'm helping out carry the battery for me? ;)
definitely.
I'd consider changing the wheels to inflatable ones.
I own myself a baseus CRJS03 jump starter. I previously had for like 5 years a cheaper and more basic one with flat li-ion battery packs, but I overexagerated twice or three times trying to start the van with a 3 liter non-diesel engine. The jump starter specs said 2 liter max...
So, the li-ion packs got damaged. I tried to find a replacement, but finally needed to buy a new jump starter quickly, so just chose the baseus one. Reading the specs it shall be able to start even a 3 liter diesel engine as far as I remember, so should last a little bit longer.
I don't think it has the supercapacitors, I assume just another lithium battery. However is different from the old one. The old one was just connecting as another battery, so could with no problems be used to power different equipment fitted with a cigarette lighter plug. The new one has a special box on the leads, once connected to a weak battery it just releases around 20% of its capacity to boost charge the battery. However I've checked lately and when using the leads from the old starter it still works the same :)
As for supercapacitors, LTO batteries are frequently used in powerfull car audio systems as supercapacitors, as they can be safely charged and discharged with a current of 10C! Of course they also can be charged / discharged with standard currents.
Well, the "die" is cast. After diving down multiple "Rabbit Holes" and becoming quite confused I've now organised and, mostly, understood all the information I can find about these capacitor based devices and I've ordered the Streetwise branded product:
I say "branded" because I'm aware of at least 3 examples of this very item with different brand names. I'm also pretty sure it's a generic Chinese made machine - which is logical as I believe China is now one of the major producers of capacitors in the world? I'm also pretty sure that the other model of machine I was interested in is also made in China and I've seen it branded with various different "manufacturer" names too. I'm aware of at least one other big volume seller which I think made in the far east and sold under different brand names. Mind you, non of that puts me off in the slightest - there's some jolly good stuff originating there these days - and has been for some time!
I have to say the Streetwize people were exceptionally helpful and even requested and forwarded quite technical info from the manufacturer which they, as a retailer, couldn't answer. Definitely service above and beyond in my opinion. Streetwize is a brand I've been aware of for quite some time and have associated it, in my mind, with rather more DIY/amateur stuff. This experience has changed my perception of them considerably and all for the better.
The purchasing arrangements have been "interesting". I bought on line from Argos because they were the best price I could find. However, turns out they don't seem to hold stock and forward the order to the Streetwize people who then arrange shipping to the customer. I was surprised to get shipping notification from Amazon. which told me they had received my package from ITD Global? and would be delivering it sometime - tomorrow - time slot still to be notified . It seems the actual shipping is done by "Amazon shipping" What a complicated world we do live in these days.
I'll let you know if it arrives in good condition and what my initial impressions are when it's delivered. I've been thinking of buying a capacitor type jump starter for many months, nearly there now and I'm really quite excited!
Ta Raaah! It's here!
In their advert the seller claims delivery (free) within 6 days to our area of the country. Order placed around lunchtime last Monday and delivered today, Thursday, just after lunch within the window promised in their carrier's email. Pretty good I think, especially as it's not at all unusual for other stuff I order from time to time almost always takes longer than quoted. Very nice friendly Amazon delivery man who obviously read the notice I'd put on my front door telling him to come round the back as I was gardening. Packaged in a very robust corrugated cardboard box which exhibited no signs of abuse of any sort. He handed the box to me and right away I got a surprise at how heavy it is. Being an electronic device I was expecting it to be feather light and actually it's not! - weighs about half or a little more than half what a Panda/Punto battery weighs! Not "too heavy", however it does give you a sense that you've bought a "serious" bit of kit!
It's early evening now and I've only just opened it as I wanted to finish with the gardening while the weather is good. Opening the plain brown corrugated cardboard box reveals an inner manufacturer box, corrugated and pretty tough with lots of illustrative imagery on the outside. This inner box has a carry handle which makes getting it out of the outer box a piece of cake. It's a nice box and I plan to keep the jump starter in it in the boot of my daily driver. This box opens easily without any damage revealing molded shock absorbent plastic inner support/protection for the device itself which is of a much higher quality than the usual expanded polystyrene stuff typically used. It's very robust and will be able to be reused many times. The top lifts off easily and allows the device itself to be lifted out of the box. Again I'm conscious of the weight of it. I like the look of it. It's deeper than the images in the adverts imply, almost a cube. The case is plastic - isn't everything these days? - but pretty robust I think. Adequate for serious amateur/semi professional use but, as it's quite heavy, I think dropping it from any real height would be unwise. The leads themselves are nicely supple with the insulation having a slightly rubbery feel to it. The clamps are really quite robust and heavy duty with both jaws on each clamp wired for electrical conduction (a nice thing to see) and the carry handle is partly (the green part) rubberized which makes carrying it much more pleasant and probably less likely to be dropped? On the front is a small LED screen which comes alive when you press the green power button. The display is really quite bright and should be easily read in bright outdoor light although the display is quite small. As I understand it these units are shipped direct from the manufacturer, although they must keep stock somewhere over here or delivery times would be longer. However it will have been in it's box for quite some time since manufacture/assembly, maybe in China? so I was wondering if there was any residual charge left in the capacitors after their shipping journey (I'm guessing they test them?) You turn it on by pressing the green button above the display so I pressed the button and the display lit up showing 40% charged! Pressing the button again starts the countdown to being ready to use - I think it's six seconds - So I pressed the button again and it started it's countdown beeps followed by a longer beep which means it's ready to try a start. I guess it's changing the configuration of the capacitors from parallel to series at this point? (so you don't turn the key until you hear the longer beep.) Of course I didn't have it connected to a battery here in the living room (and I'd made very sure the clamps were attached to their insulated docks before I did this to avoid a short!) The instructions state that if you don't do anything (ie abandon the start) then the device switches off (ie breaks the circuit to the jump leads) after 10 seconds. and, right enough, the screen went dark at that point. So, seems to be working as the instructions say. Tomorrow I'm going to connect it to the old battery I took out of the Punto a couple of years ago because it was failing. Seems to manage to still achieve some charge though so I'll note the open circuit voltage before I start and see if it'll charge the device fully. The instructions say that a battery with more than 5 volts in it should achieve this so it'll be interesting to see what it does. Then all I'll need is for one of the "family fleet" vehicles to need a jump to see if it can really earn it's keep (I'm confident it can). The instructions claim this unit can start both petrol and diesel engines up to 8 litres so it shouldn't even break sweat on the stuff I might use it on.
The main way I would see this being used will be to connect both leads to the depleted vehicle battery and charge it from the partially depleted vehicle battery. This will be by far the quickest way to do it, probably under 5 minutes to fully charged unless the battery is pretty marginal and is going to work in most "flat battery" situations. Why do I say this? Because most vehicles that fail to start "on the key" do so because the battery is only just below the voltage where their battery can turn the engine over - So, often around the 9 or 10 volts and only needs a wee bit of a "leg up" to turn the engine over. However, if the voltage in the vehicle battery is under 5 volts the jump pack won't charge in this way. The simplest way to overcome this would be to charge it on another vehicle if you can find an obliging bystander who'll allow you to. I'd be quite confident in doing this and would have no worries about causing damage to their vehicle, although I'd connect the neg lead to an earth rather than the neg battery terminal "just in case". In my situation I'm most likely to be helping a family member, neighbour or friend so I'd just charge up from my own car in this situation. However it can also be charged via a USB connection and it's nice to find a suitable lead and 3 pin 240 volt charger included in the box - it'll take a lot longer though I'd think?
So, at this moment in time, I'm absolutely delighted with my purchase and can't wait for the opportunity to use it "in anger".
Great!
Looking at the weight, might be LTO :D However to be frank I have no idea how much that many supercapacitors should weigh...
The most important is it's there ;) Hope you'll be happy with it :) And can't wait to hear about the impressions from the first use.
I'd never heard of LTO batteries: https://nichiconbattery.com/lto-battery-is-an-alternative-to-supercapacitor/ sounds very interesting.
The streetwize packaging is clearly labeled "12V - Super Capacitor Jump Starter" If I were marketing it I'd make a point of highlighting that it was based around LTO technology to differentiate it from other products which use super capacitors in the hope it would give my product an advantage. There are some very interesting claims made on the front of the box which might point more towards it having some sort of storage capacity, which might point towards LTO batteries? It states "Next generation Battery-less Jump Starter" and "No built in battery" and "Does not drain during storage" and "Jump start several vehicles with one charge" and "Jump starts petrol and diesel vehicles up to 8L in under 30 seconds". The "does not drain during storage" and the main description of it being a "Super Capacitor Jump Starter" just might imply that it contains these LTO jobbies? Either way, if it does it's job I'll be delighted and if it has LTO capacitors then their additional ability to act as batteries can only be a bonus.
I'm charging up my camera battery just now and will try to post some pictures later.
One of the videos I came across on you tube when I was researching it was this one which describes the product and shows it in use -
In the States it would seem to be branded as "Keen Power" (I've seen another advert in which it was being sold under a different brand name and there seem to be some slightly different versions, I've seen one where the trim colour was yellow - mine's green like the one shown here - on Amazon branded streetwize but later in the descriptive text calling itself 4TRESS and it's part number is SWPP21 whereas mine is SWPP20 but I think they are all the same internally.) In the video he has obviously charged it up before starting the video because the device is fully charged when he first uses it. Maybe he used the USB charger? However he then shows how it charges from the depleted battery after he's demonstrated the first start.
The Amazon advert, if you're interested, can be viewed here: https://www.amazon.co.uk/Streetwize...hvtargid=pla-2195324447971&psc=1&gad_source=1 It costs slightly more from amazon than Argos.
I'd take a bet there's a Mega factory somewhere in the East churning these out by the million with slight cosmetic differences depending on where they are being sold and under what brand name? That may be no bad thing though if the components are of good quality. Anyway, I've "made my bed" and now I'm going to "lie in it" and it's looking comfortable enough so far.
Sorry folks, no pictures I'm afraid. The camera battery is refusing to accept a charge, probably because I've left it too long and it's now completely discharged. Another good reason for me to buy that google pixel phone I've been looking at!
Mind you, from the videos above you'll get a good idea what it looks like and what it's all about. Probably the only thing I could have captured which isn't shown in any detail, would be the small led display which, predictably and unsurprisingly, shows the donor battery voltage (that's the vehicle battery). Below it the voltage the jump starter is charging to at that moment in time and, to it's right, that voltage as a %age of fully charged. When it hits 15 volts and 100% it's fully charged and ready for you to push the green button and, after the countdown (which I can confirm is 6 seconds) operate the starter motor. I'm interested to know the output voltage during the countdown period - I'm wondering if this is to allow for diesels to use preheat? I'm intending to use a voltmeter to monitor this the first time I use it in a "real life" situation. I can't find anything in the instructions about this. Mind you there's only one diesel in the "family fleet" and non of my friends has one any more so maybe of little relevance for me - I try to stay well away from modern diesels anyway!
For the camera battery, check the nominal voltage on the battery housing. Use another charger / battery / adapter of similar voltage to charge the camera battery directly just to have it a voltage similar to nominal. And then try the standard charging method :) Unless the battery is totally dead it should work :)
As for the LTO batteries, I'm having 2 of those in my campervan setup, mostly due to high discharging current (up to 10C, which in theory might give me up to 2000 A :D, but being limited by the BMS, I can still use it for ironing or even welding) and security. And it is much more durable.
The LTO batteries are not that much popular, so would be hard to make a marketing slogan out of it :)
Trying to charge with a "generic" charger would be very difficult as the connections are shrouded and small. Also there are actually 4 connections. The two outside are marked pos and neg but the two in the middle have weird symbols I've never seen before. This is the type of battery: https://www.battery.uk.com/Replacem...-For-PANASONIC-Lumix-DMC-FZ7-S-CS-PDS006.html and it came with it's own stand alone charger. The original Panasonic (Matsushita) branded battery is actually rated at 7.2 volts and 710 mAH whereas the replacements all seem now to be 7.4Volts and 750mAH (progress in battery construction I suppose?) Previously to charge it you install the battery into the charger and plug the charger lead into a 3 pin mains socket. When switched on a green light illuminates and stays on until the battery is charged. I actually have two batteries, one is a cheap generic jobbie, bought just a few years ago, which has rapidly declined until it will now only allow one or two pictures to be taken before going flat (and won't do flash at all) so I've given up using it. The original Panasonic battery, which came with the camera maybe 15 years ago? (the camera is a Lumix DMC-FZ7) when installed into the charger and switched on sees the green light illuminate briefly, for maybe one or two seconds, and then switches off - just as it does when fully charged. The cheap battery will charge for maybe 15 to 20 minutes in the same charger before the light goes out but, as I said above, only takes on enough charge to manage a couple of shots before depletion.
So the charger seems to be fine, I think the original battery has failed internally and catastrophically because last time I charged it - which was probably around Christmas time, it happily accepted a good charge - although I have noticed it's capacity was less than it had been in that it takes less pictures than in past years before needing a recharge. I seem to remember reading somewhere that if you let Li-ion batteries discharge completely they will be very difficult to charge again and can actually start internally decomposing? A new good quality battery seems to be just under £20 from online suppliers (cheapies from under £10 - but I won't be caught out by going that route again) so I think a new battery is probably the answer, especially given that the existing battery must be at least 15 years old.
Thank you very much for your help and suggestions.
Naming change to let people think they have something bigger / better / more powerfull. The powertools batteries are also higher rated since 10 or 12 years. 12V became 14,4V, 18V became 20V...
The nominal voltage of a single Li-Ion 18650 cell is 3,6V. But they agreed it will be better to sell it as 4 V instead :D
Check with a multimeter what is the voltage between the external terminals of the original battery.
Those supplied chargers frequently check only the voltage to determine if the battery is OK and safe to use. When it happens that their voltage is below the limit, it just won't start charging.
Of course I agree that the battery might have low capacity or might be damaged due to its age, but I will however try to check if the problem is not only a slightly too low voltage, below a set threshold.
I'm using a power adapter with modified output from 3,5 to 18V with small clamps. If they are too big, I just clamp them on the multimeter narrow terminals :)
It doesn't take longer than a couple of minutes.
Ok. Neither of my mulimeters have thin enough probes to get into the shrouding so I just used a couple of pins to probe the two outer battery terminals (labeled + and - on the casing) on the flat battery and there's absolutely no voltage there - the battery seems to be totally discharged. I double checked that the pins, held against the probe tips, were actually making contact by trying them on a double A cell and it does give a reading. So the camera battery would seem to be completely discharged.
@the green vanper If I make up a battery pack using double A cells I could achieve 7.5 volts with 5 cells which I could apply to the "dead" camera li-ion battery in an attempt to charge it enough that when loaded into the charger then it would be "recognized" and charging proper will commence? How long might I need to keep the voltage sourced from the AA battery pack connected to the camera battery to wake it up enough?
USB is 5V :) But you have to have a cable with USB-A or USB-C at one end, and loose cables on the other and.
5 AA or AAA batteries would also be OK.
2 18650 Li-Ion batteries would also work.
I really have no idea how much time it would take. I can't recall having a totally dead battery...
On the other hand playing with Li-Ion batteries might be dangerous... If you decide to do so, monitor the temperature of the camera battery to be sure you won't have a burning ions fountain in the middle of the living room / kitchen / workshop / shed :D
It was interesting finding out the battery is totally dead and thinking about how I could cobble up a battery pack and some sort of thin contacts to reach the battery terminals. However, now I'm thinking "is it worth trying to resurrect such an old battery which might not be all that reliable when a good quality new one isn't all that expensive?" The camera, although somewhat worn from handling, still takes very nice snaps. So i think I'll just buy a new battery - but thanks for your suggestion and the entertaining half hour in the workshop it gave me.
Yes, it's always that kind of thinking. The new battery will come in a couple of days, so having in mind it's not that expensive I think it's not worth it.
Unless you want to share with us your joy coming from the new toy tonight, or tomorrow :D
"New toy" being the jump pack? I had intended to experiment with it today but unfortunately I woke up at about 4am today with a very sore stomach and only really got control of myself around lunchtime. Experimenting with the wee camera battery has provided a nice wee distraction but taking on the jump pack is going to have to wait 'till tomorrow I'm afraid.
You'll have to leave the lights on one of the cars overnight. Although, you'll have to fend off the neighbours knocking the door to tell you.
