marc.knuckle
- Joined
- Nov 12, 2007
- Messages
- 35
- Points
- 11
unfortuantely my wipers on the front have stopped working properly. at first they work most times when i first start the car up apart from the one wipe up-press that i have to hold or it stops straight away as soon as i let go of the lever and this can be anywhere on the windscreen. it then stops working completely most journeys and the only way to get it working is to turn the engine off and on (the universal cure for problem technology) but after a bit it stops again.
i assume it is the motor but is this simple to replace or does it need computer work at the same time?
cheers
cheers
