Technical Hydraulic Clutch
hbcmike
United Kingdom.
Hi all - the hydraulic clutch needs adjusting/bleeding as it sometimes refuses to fully release and graunches into reverse. Before I dive in and have a play, I hoped someone might have some experience of this. I can see what looks to be a bleed nipple on the slave cylinder at the clutch end, but no obvious flats for undoing for bleeding. The service manual claims it's a cable release, but they're wrong!
Any info appreciated.
Mike.
I doubt it needs just bleeding! Are there any visible leaks? Pull back the seal on the slave and check for leaks. A very common fault on the multipla is the master cylinder spring breaking, but this will leave the pedal on the floor. Does the pedal sit in line with the brake?
Check out the multi forum off the main website...
www.multiplaowners.co.uk
http://uk.groups.yahoo.com/group/multiplaowners/
A known problem...yes its probably the master cylinder spring gone. Is there about 3/4 of an inch of free play before you feel any pressure?
Well documented...cyls are about 26 quid but it is possible but I am not sure if advisable to replace the bits from within the car without removing the cylinder!
Its all on there!!
Moriarty the mundane
