Right, firstly, I'm new, so be kind!
And secondly, I hope this is in the correct section! So mods, please move if you feel necessary!
Right, the situation, my mate has got one of these subwoofers in his Sporting, and my poverty spec Punto lacks a but of "oomff". So if I can pick one up cheap enough and they're easy to fit, I think I will. Although it might not be the best quality, it's perfect for what I want / need. I know you guys will say its not worth it, but i've thought it through, and this is what i want
I've tried searching about Google and various forums, and came across this
Seems ok, but is there anything I need to know, that "tutorial" is quite old, and I didn't know if time has brought about a cheaper / easier method.
The Headunit i've got is a Kenwood KDC-W3044G
The manual can be found here (PDF File]
According to the manual, it has these connections, so should it be a simple job?
My Punto is a poverty spec one, so its got no rear speakers installed.
I hope I've provided enough information, anything else, just ask.
Thanks in advance
Michael
Buy a wiring kit that supports your 100w sub. -- £15 - £20
This includes a Power lead, L/R audio leads (Phono cable), speaker wire, a blue wire to turn your sub on and off and a ground lead.
E.G http://www.nexxia.co.uk/CarInstallaccessories/amplifier_wiring_kit.htm
TUTORIAL
You'll need to connect the power lead to your car battery, need to find a way into the engine from the dash inside the car. Run this lead to the rear of the car alongside the passenger side.
Depending on whether you have an aftermarket stereo or the standard one installed you'll need to hook up the blue wire to the back of the stereo, this tells the SUB to turn on and off when you activate your stereo.
On Aftermarket there should be a wire to connect this to, on Punto stereo you must find a wire that can power on and off (eg. Ignition wire for stereo).
Then depending on stereo - hook up the phono audio leads or speaker wire. You can get Phono audio lead adapters that go no the speaker wires of the stereo on Punto Stereo's.
Both these wires go to the back of car (assuming your sub is here).
At the back you'll need to hook up the ground lead to somewhere like a bolt on your boot somewhere, with good connectivity with car surface.
Hook up all the wires to the subwoofer, (assuming it has an Amplifier on it).
Put FUSE in power lead.
Thanks in advance
Michael
