General High revs.
General High revs.
BuzzBox
little kimble, bucks
Please can anyone help. I have a 94 panda 1000 fire which runs fine when cold but when warm and on daily stop start trip to work of about 6 miles by the time i get to work the revs are way above normal idle as if the throttle is stuck open a bit, cleaned throttle cable connection to carb but no difference. Any ideas . Car has only done 49,000. Many thanks
is it injection ?
beacuse mine did that a couple of times while the alternator was breaking.
it some wierd ECU confusion sometimes.
hope you find it.
take the air box off just to chek its not stuck open.
gd luck
aran.
Are you slowly pushing the choke in as the engine gets warmer?
How about an ECU reload. You can do a series of actions which resets the ECU. Perhaps if you tried this you could narrow it down a little. Mine had a similar problem and a combination of doing this followed up by checking and adjusting the timing periodically kept it in check.
