HGT 147 Fiat ECU Scan
M
Matthew
Hi All,
I'm having trouble connecting to my ECU with Fiat ECU Scan.
I have the stock KKL cable and the fiat 3 pin adapter, I can connect to my ABS fine when I run a scan but cannot see the Bosch Motronic M2.10.4 for the injection side of things. I know you have to have the full version of the software for this ECU, but i thought it would let me "test connect" I cant conect at all.
Has anybody successfully connected to this ECU?
According to the interface page I should be able to connect without shorting any pins or anything like that.
I've posted on the Fiat ECU Scan forum but not having much look, anyone managed with cars with the same ecu, marea,etc?
Hi Everyone, found the cause of the problem! I was connected to the wrong connector! For anyone in the future, the connectors are in the following location:-
Bravo 147 HGT
ECU Connector - Drivers side as you look at the engine, inbetween suspension strut and the engine
ABS connector - Passenger side as you look at the engine, atached to the Fuse Box.
Airbag connector - have yet to find it!
Will try to get a picture of the engine bay with the connectors circled.
Matt
M
2
337
M
F
7K
F1-ANG
F
A
1
11K
Angelo
A
M
1
364
Dark Lurker
