Earlofdavetona
Hi all.
I have seen the thread about the rad fan making contact with the rad and scraping it when it cuts in. On Saturday last the car failed its mot and one of the advisories was a coolant leak from the rad. The fan has been scraping the rad for the last month or so and has obviously finally cut through the matrix. Until I get the car apart I can’t tell what the issue with the fan is. Does anyone know?
Next thing, when I changed the clutch last year I saw a trail of pink coolant residue on the block that looked like it came from behind the oil cooler/filter housing. Is there a common water leak on the Abarth 500 from the oil cooler assembly or anywhere else that anyone is aware of? Of course it could be coming from higher up the engine but I never had the front end off completely to investigate properly.
