- Joined
- Nov 9, 2009
- Messages
- 26
- Points
- 57
Hi
I've recently changed the radiator on my 98 Barchetta but i'm still having problems with the water temperature rising and flowing out around the water reservoir cap (replaced). I don't know if it's the water pump or thermostat? The fan comes on as the radiator heats up, but i can't see any water returning into the reservoir. The car ran out of water when the radiator failed and i needed to replace some corroded pipes that run into the oil cooler, so the system seems seams to be sealed up and the heating works fine.
Would a faulty thermostat stop the water from flowing around the system?
Bryan
PS. Had the timing belt changed recently, but not the water pump.
Bryan
