Technical Heater not working, but aircon works brilliantly.
Dantelu
Hello.
So ever since I've got this car the heater is not working, the Aircon though works marvelously.
No Fuse issues found, but sometimes the fan turns on by itself(Very odd).
I wonder if this could be something like the Resistor of some newer models.
Does anyone have any idea or experience with this?
Do you guys know where the Resistor is?
Thank you very much! :slayer:
Factory aircon with temperature dial or just blue/red scale?
If yes: does it output hot if you turn in all the way to hot?
I'd look for groundfault on either of the dash grounds as mine sometimes started blowing when it was set to 0.
My fan jumps between 2 x positions..over bumps. Annoying but not an issue.
Hello.
Top.up the coolant.and open bleed screws.
you probably have little cooling water circulating.
