there are less parts on the whole of the cinquecento then there are that are common issues on these
hope mine is going to be some what reliable and wish I had looked at this before hand!
oh and 2008 its coming up to its 5 year cambelt interval :devil: if its not been done negotiate a price with your supplying dealer they might even do it if you threaten to walk away
Those common issues don't affect every gp but most are very cheap fixes......
Fault - Noise when turning
Cure - Top strut bearings
£25 ish per bearing about 45 mins labour
https://www.fiatforum.com/grande-pu...-top-bearing-removal-service-replacement.html
Fault - Knock while driving
Cure - Drop link (check for movement)
£15 drop link and 30 mins absolute max easy DIY job
https://www.fiatforum.com/stilo-gui...ur-drop-links-anti-roll-bar-links-30mins.html
Fault - Smell of oil - breather hose/pipe (split)
Cure - modified hose & pipe
hose is about £12 off flea bay 2 jublie clips and 15 mins or so to sort at home
https://www.fiatforum.com/grande-punto-guides/262269-breather-hose-replacement-1-2-1-4-8v.html
Fault -Tailgate not opening
Cure - water on connector at lock, clean connector @ fit new lock.
I blathered mine with waxoil when it was new only affects some
Fault - Power steering light on - sometimes with noise/creak from column area
Cure - Various causes (power supply,column,connections)
Often caused by a poor battery
Fault - Dashboard top vent trim - the long trim which directs air
to windscreen can distort & stick up at drivers side
Cure - fitment of new trim.
I ignored mine no real issue bar cosmetic
Fault -Drivers door - not opening from inside.
Cure - requires lock
Chances are it will have already been replaced mine went at just outside the 3rd year https://www.fiatforum.com/grande-punto-guides/238842-drivers-door-lock-replacement-repair.html
Fault - Electric window(s) not working
Cure - poor/loose connection at drivers door switchbank.
5 min job use guide above to remove switch unit remove cable blast with contact cleaner and shove back together
Fault - Rear manual window not moving
Cure - Regulator seized, fit new regulator *TIP operate weekly to prevent seizure *
not an issue on 3 door
Fault - High coolant temperature warning,normally at start up.
Cure - software update
Been at a fiat dealer they should have already sorted this
Fault - Horn - requires a firm press to operate.
Cure - lubrication of horn contacts DANGER airbag - dealer only!
Check the horn works when you pick it up if its hard to press get them to sort it
Fault -Rear doors - sticking intermittently from outside
Cure - modified outer door handles available.
not on 3 door
Fault - Headlights staying on
Cure - water in engine bay fusebox/connections
Usually caused by someone meddling with the fuse box who lacks the ability to refit it or the little arch flap missing its fixings
Fault - Screeching noise from starter motor when starting
Cure - battery voltage low, get battery tested correctly and/or fit battery (360a)
fairly self explanatory dying battery = problem
Fault - Heater fan not working or only works on some speeds
Cure - depends on fault look here
doesnt affect every car see FAQ can be sorted cheaply
So enjoy your new car
