OK, so I know this seems to be a common problem, but I thought I'd better check to see what the latest is on it.
This morning, I went to get something out of the glove box, and it opened fine. However, when I came to open it again a few minutes later, it wouldn't open. The handle moves OK, and there's a small amount of movement at the side by the handle (a couple of mm), but the left-hand side of the glove box seems stuck solid with no movement at all.
The car is a 53-plate post-facelift Mk 2 1.3, and IIRC has a catch at either side of the glove box, not a central catch as is described in some of the older threads here - but I could be wrong there, as it's not something you tend to pay much attention to. (If I am right, fishing about in the middle of the door with a screwdriver to trip the catch probably won't work!)
So I'm wondering if this is a known issue with this type of glove box, what the cause could be, and what the solution is. The only suggestion I've had so far is from my dad, with his usual response to any problem of "get a crowbar on it". However, as there's the airbag above the glove box, I don't think this is a very sensible course of action!
Any tips or suggestions? Need to get this sorted ASAP as SWMBO is panicking about not being able to get her stuff out of there...
