Technical Gearbox input shaft seal
Rob0
South Africa
Does anyone perhaps no the size of a replacement oil seal of the input shaft (spigot) on the gold plate gearbox, mine is leaking gearbox oil and I want to buy one before removing the gearbox it's for the uno fire 1.1 94 model
My gearbox is this type, and thanks for the drawings if I can get the OD and ID of the seal then I can get one I'm from south africa and the spares shop by us don't have that parts on their system and they require a sample I'm still driving the car, and if I have to take the old seal out then I'll be without a car for a few days and Its my everyday car
This page will show you the different gearboxes used in the Uno:
That seal has the same part number for all versions, until it gets deleted in a later revision.
Sorry I don't know the dimensions of the seal, unless searching by part number gives you anything?
It does look like a basic rubber O ring though. When I did my thermostat I found a cracked O ring oil seal and got a replacement from our local hardware store.
Thanks for your help I appreciate it will see if this people can help me with the part number
