Vafung19802
Hi all
Complete newbie to this forum and in desperate need of help .
Got a 1991 uno turbo had this for over 20 years started on the button but unfortunately had a gap where I didn’t start it for 3 years (garaged)
Upon trying to start it in February 2021 I noticed there was no buzzing from fuel pump , so changed this and fuel filter under the bonnet ,
Fuel pump cuts in and buzzes but still would not start engine cranks , did a spark test with a tester and I’m getting full spark ,
I could only put it down to fuel issues so therefore disconnected the fuel pipe that goes directly into the injector rail and put it directly in to a bottle to see if there was any fuel spray , and sure enough the was .
Really scratching my head over this one and thinking the injectors could be blocked ?
Or if you guys could point anything out to check ?
The fuel that was originally in the tank smelt like varnish this was emptied and clean fuel added
Much appreciated guys for help in advance
Thank you
Thank you
