garethhare
- Joined
- Jul 21, 2018
- Messages
- 2
- Points
- 1
I just changed my clutch on my van I found it easier to remove the bumper and crash bsr then the rad pack to access the gearbox proped the van up remove the the drive shafts remove the thermostat houseing prup up the engine remove the starter bolts 2 allanbolts from underside and 1 from top then remove the numerous bolds and studs holding the gearbox and remove gearbox mount and clutch slave there is also an earth strap to top of the box just pry off the box and sit it on chassis leg don't need to remove the shift cables
