Redlight
Hello,
I own a 2014 Fiat Punto III 1.4 57Kw BiFuel (factory LPG installation). For the past month, I've been struggling with a fault that I haven't been able to resolve yet. The vehicle reports misfire codes P0300, P0301, P0302, P0303, and P0304. Additionally, it shows error P0351 (Ignition Coil A Primary/Secondary Circuit Malfunction). The vehicle is not running on a rich mixture, and the lambda regulation is functioning correctly.
First, I replaced the spark plugs, then the ignition cables—without any change. I then measured the ignition coil pack (55200112) and consistently got a reading of 0.6 ohms on all four pins relative to the first pin. So the ignition coil pack should be fine as well.
The fault occurs both on LPG and gasoline, but only above 3500 RPM (around 120 km/h). For example, when driving in the city, the issue never appears. The vehicle also has an irregular idle—sometimes it stumbles briefly but then runs normally again.
I don't know where to proceed next, and I don't want to blindly replace working parts with new ones.
- Model
- Punto III 1.4 57Kw Bifuel
- Year
- 2014
- Mileage
- 197000
