bilopapa
hi howsit i need some help....my fiiat uno 1.1 fire is overheating and i dont know what could be the problem....secondly i dont know how to set the timing also...please anyone to assist...highly appreciated
thanx alot brother....there is coolant.....fan comes on but very seldom not like before...water pump is now always looking wet i dnw why......when i bought the car it didn't have a thermostat i installed one......so il check what u said i should..hopefully i come rightHello,
Things to check and confirm:
- presence of coolant in the system (what is it? water? or water / alcohol mixture?)
- fan blower working (eventually the fuse / relay)
- water pump + belt
- thermostat functionnality
In which conditions is the car overheating?
I don't know if you know the principle ot the car cooling system, if not - get to know and understand it, it will allow you to diagnose a little bit further.
and its leaking from the radiator cap...i changed the ca twice still same problemthanx alot brother....there is coolant.....fan comes on but very seldom not like before...water pump is now always looking wet i dnw why......when i bought the car it didn't have a thermostat i installed one......so il check what u said i should..hopefully i come right
yes the thermostat was present but not functional...i have cold air in the ventalition system but no heater...maybe its blocked...welsh plugs started giving in toThermostat is the part that controls the coolant temperature and changes the circulation. I can't imagine a car engine without one.
And the water pump shouldn't be wet on the outside!
There's an overflow reservoir in the cooling system. Is there enough fluid? Perhaps the system needs bleeding?
okay so i think thats the problem thenThe cap needs to be a pressure cap.
No hot air in the heater seems like airlocks in the system. That could cause overheating. And needs bleeding.
so its been leaking oil from the tapet cover gasket...eg like its sweating and there's alot of oil on the distributor....its leaking but not alot but around the area of the of tapet cover theres oilas mentioned bleed the system properly - check if there is circulation through the heater hoses. Matrix could be blocked, but with the other symptoms it sounds like you may have a head gasket issue.. you should only need to bleed once.. make sure there is circulation through the radiator - to prove the water pump is pumping and if there is, but still overheating, pressure test the cooling system or do a CO test to confirm if there is a head gasket issue..
