Technical Fiat Grande Punto ESP, Hill holder ASR Disconnect
kierandyte
London
Hello there
I purchased a Fiat Grande punto tjet 2009 yesterday but it had the following faults:
ESP not available
Hill holder not available
ASR disconnect
Check power steering
Are these all related if so, what is the most common fix?
Cheers Kieran
Hi :)
Hopefully your purchase price reflected the work required..
Often a combination of:
Black earth cable
Brake light switch
Rear hatch wiring
What did you use to get the codes?
Levels of accuracy can vary ;-)
Hey thanks for the reply,
where do i actually find these cables?
i cant seems to read anycodes though the obd
Hi :)
Black earth cable
Brake light switch
Rear hatch wiring
Sorry for jacking the thread. I had the same issue the other night. I remember 100% that it was raining quite hard. It hasn't happened since. I have noticed that a tiny bit of my left brake light, where it lines up with the boot is chipped off. Going by what you have posted, I think you may be right. Could be water trickling into the rear hatch wiring. I don't have any codes as it went off. Also, sorry for being a pain but where is the old connection? I don't have a clue or a manual. Thanks in advance
Hi :)
Black earth cable
Brake light switch
Rear hatch wiring
Hi i have the same problem i have the C0051 Error and the U1715 what could it be? Best regards
Hello there
ESP not available
ASR disconnect
Cheers Kieran
Hi did you find out the issue? Best regards
Hello there
ESP not available
ASR disconnect
Cheers Kieran
I had this exact issue it was the wire from car loom!! To plug for abs front driver side could be one of others I brought new sensors only to find it was a broken wire making intermittent connection youll have to strip the outer sheath off the abs wire that comes through through inner wing hopefully that solve the problem for you too
