FiatDucatoCamperUK
Hi all, I've been reading through all your posts over this week looking for potential solutions to the imobiliser issues I'm facing, but can't quite put a finger on it..
I own a Ducato for many years now, which mostly serves as a motor home. For over 2 year now, I've been faced with a strange imobiliser problem which is hard to explain, and mechanics were unable to resolve on 2 ocassions.
The issue appeard this week again, I was driving my car when all of a sudden, my windshield washers turned on by themselves, the imobiliser lock icon appeared, and my indicators/ headlights, even windows stopped working. I pulled over, switched the engine off, and was unable to turn it back on, I had to unplug the battery to stop the windshield washer spraying.
After 10 minutes I plugged the battery back, I was able to start the car, and made it back home, but again, just as I was a mile away, the same thing happened, the imobiliser icon popped up, and washer started spraying non stop.
Ive charged the battery fully today, plugged it in, and the car starts no problem, but with the engine off, when I pressed the open door button on the key fob, the car did not unlock, but the windshield washer started spraying, and I was unable to start the engine no more, had to, again unplug the battery and wait for it to reset.
It seems the key fob is one cause of this, but the issue also happens while driving, which is my biggest safety concern.
The low battery voltage seems to be causing this, but I don't know what might be causing the problem.
I thougt of fixing/ replacing the bcm, which is what the mechanic suggested, but im not sure if this is it, as everything works when the imobiliser problem is not present.
Any help or advice is greatly appreciated.
- Model
- Fiat Ducato 2.3 Multijet 2013
- Year
- 2013
- Mileage
- 250000
