Hello!
I have a problem with the clutch on my S reg Fiat Brava 80. I've read the other threads on this subject, but I'm still confused, and I was hoping someone could help me out! (Please forgive me if I ask some stupid questions - I'm not good with cars)
Every now and then the clutch pedal would stay down, and I would have to flick it back up, then it would be ok.
The brake-fluid warning light would come on intermittantly, but go off when I filled the brake reservoir.
The other day the clutch pedal went all loose, and the car was stuck in neutral, so I had to tow it home.
I guess the Brava has a hydrolic clutch - if so, where is the reservoir, or does it use the brake-fluid reservoir?
If its a hydrolic clutch, does it also have a cable?
Where should I start?
Many thanks in advance, Rob.
