D dj1959 New member Joined Jan 20, 2013 Messages 4 Points 2 Feb 26, 2013 #1 i am after exhaust hangers for 2007 ducato,just wondered if there are any universal ones, as fiat have none for 3 days and i need mot. thanks
T tommytopgun New member Joined Jan 29, 2013 Messages 95 Points 19 Feb 26, 2013 #2 Exhaust hangers are pretty much universal, as long as they're a similar size to the originals you should be alright. Try ebay. http://www.ebay.co.uk/itm/290545121811?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 I used these to replace mine. 2008 multi jet 100 This post contains affiliate links which may earn a commission at no additional cost to you.
OP OP D dj1959 New member Joined Jan 20, 2013 Messages 4 Points 2 Feb 26, 2013 #3 thanks. ordered. hopefully come quick, if not will always use,
M moodrater Member Joined Dec 15, 2011 Messages 727 Points 129 Location omagh Feb 26, 2013 #4 Nice find those are cheap, I was about to order these 'uprated' ones. http://www.ebay.co.uk/itm/3-x-Uprat...hicles_CarParts_SM&hash=item4abb10eabe&_uhb=1 This post contains affiliate links which may earn a commission at no additional cost to you.
T tommytopgun New member Joined Jan 29, 2013 Messages 95 Points 19 Feb 26, 2013 #5 I thought about those, but I've alot of work to do on this van before its back on the road.
M moodrater Member Joined Dec 15, 2011 Messages 727 Points 129 Location omagh Feb 26, 2013 #6 tommytopgun said: I thought about those, but I've alot of work to do on this van before its back on the road. Click to expand... OEM rubber parts are such ****e nowadays, my brothers ford galaxys exhaust is held on with rubbers from my dads 78 audi 100, my 05 ducato has the rubbers from the 95 ducato I scrapped still holding up.
T tommytopgun New member Joined Jan 29, 2013 Messages 95 Points 19 Feb 26, 2013 #7 You're right, I couldn't believe how thin the original rubbers, especially for such a large back box.
mike.T New member Joined May 28, 2008 Messages 26 Points 7 Location Gloucester/Cabo de Gata Feb 28, 2013 #8 Exhaust hangers are pretty much universal,as said before Try you local tyre/exhaust /motorfactor's They should be able to sort you out . Mike
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,293 Points 8,215 Location Near the M4 Feb 28, 2013 #9 tommytopgun said: You're right, I couldn't believe how thin the original rubbers, especially for such a large back box. Click to expand... I always put a LARGE section cable tie / tie wrap, aound the rear mount rubber, the rubber keeps it flexible.. BUT the strapping of the tie mean it's supporting the weight a lot more effectively, I've yet to break a rubber mount since doing this 15 years ago, ( it should Pass MOT inspections too -even if the rubber has perished / LET-GO) Charlie
D Dreamcatcher New member Parked in the garage Joined Jan 1, 2013 Messages 24 Points 6 Feb 28, 2013 #10 Thanks, tommytopgun, just ordered a set to replace my originals which are held together with jubille clips, Ivan
