Hello,
I´ve been trying to fix a flutuanting idle on a 2009 Fiat 500 1.2. Breather hoses were cracked and Map sensor covered in oil. Both replaced and throthle body cleaned. Now idle is stable unless You turn on full beam headlights. Then it goes up & down opening the butterfly on the throthle body and almost stalling. Spark plugs, cables and coil pack replaced. O2 sensor above cat also replaced.
I´ve read some topics here and now I want to test the evap solenoid valve. I disconected the blue pipe that comes from the fuel tank and it´s always closed, no vacuum, even with a full warm engine.
When does the evap valve opens? is there a way to test it further?
Hope someone can help.
BR,
Vitsove
BR,
Vitsove
