Technical error front left door open
ram72pin
italy
Hello everyone
on Fiat Scudo 2007 it always gives me error front left door open
I found the connector under the lock, even disconnecting it the error remains.
Can you tell me which wires I have to 'short circuit' to make it always see the door closed and 'isolate' the error?
The lock on this model is not repairable as it is a single piece of cast plastic
As long as the door closes. Ignore the light on the dash. MOT examiner will👍😁
But try putting all wires (on out plug) to earth (a simple light or multi tester) will single out + wires.
Test the rest to earth. Light should extinguish. As sensor not in lock.
