Technical error code b1029 any ideas???
benjishearer
dagenham
i took my car for a diagnostic the other day i got 2 codes come up one was p0571-cruise control/brake switch a circuit malfunction
other was
b1029-rear air thermo sensor inactive(apperantly i found it on google please tell me if diffrent)
now i dont no how i go about solving these issues im not very good with cars lol soo please help someone. my car keeps juddering when pulling away while engine is code any ideas? thanks :cool:
B1029 yea that was it i found on google it said rear termo sensor inactive and im not sure what that means thanks.
that means absolutly nuffin 2 sum1 like me with half a brain is it a seriuos problem and could it cause the juddering???
rite them error codes arnt anything major to worry about then ?? my breaks lights r fine and as for the map sensor bit wot does that do? wot im after is a explanation y my car judders wen pullin away but dnt fink them codes have much todo with that do they??? thanks alot
Do a search or wiki on MAP sensor
"Juddering when pulling away" is a bit vague, care to enlarge?
Is it only when using the clutch or after clutch is up?
Does it happen in all gears or at a certain rpm?
Is it engine rpm related or car speed related?
Is it only when engine is cold?
only when cars cold and only when pulling away just past the biting point it does it and it only does it at about 2000 rpm nything less and it dont but then i hardly moving pulling away considering it is a massive 5door with a tiny 1.2 engine lol
63000 and not sure if clutch has been changed b4 is there a way i can tell if it is the clutch atall?
Well, I am being a bit diffucult here, but please write correct terms and words. Examples given:
rite
arnt
r
2
sum1
sed
wot
y
wen
dnt
b4
Bloody hell, this isn't a SMS chat.
Morten - not from the UK.
sorry about that its because im so use to it when im typing on the pc. i suppose its just lazy. only fing with a garage is they said they cant tell themself and hooking it up to the computer only gave them two codes which apparently wouldnt affect my car in that way
