I have a 2.8 idtd I changed the cam belt last week and it wont start. 1st point, flywheel pin in, pump pin in, cam mark correct. It tries to start and feels like too little fuel going in and white smoke coming out. I checked the engine stop and there is no current. i took it off and the pin was stuck fast. some wd40 later and it now moves. i then checked the ignition switch , the yellow/grey wire and there is no current. my question is, did the siezure blow a fuse, (a hidden fuse,)? or a relay or something else? also tried to buy a new engine but cant find one for my model, thanks in anticipation.
