Technical Engine shaking when cold Fiat 500x 1.6 multijet
Danielszilvasi
London
Hi guys I've got a Fiat 500x 2016 1.6 multijet has an issue when it's cold it's shudders/hunting as soon as it warms up it goes away there are no fault codes have had new glow plugs and glow plug relay throttle body suction control valve EGR cleaned and checked DPF regeneration map sensor and maf sensor tried to book it in with a fiat specialist he told me to take it straight to the main dealer does does anybody have any suggestions before I sell the car
Model
500x
Year
2016
Mileage
60000
Maybe some more detailed diagnostics along with a "live data" recording at the time it is showing the fault.
Can be air getting into fuel inlet when stationary, faulty fuel pressure regulator, sticky injector or even a loose electrical connection.
Does it blow white smoke from exhaust which smells of diesel and worse if weather cold when first starting?
It does look like a "spare parts cannon" has been shot at it rather than a good diagnosis.
Hi its had a smoke test done no leaks it dose have a strong smell of unburnt diesel but has had the injectors sent off for testing came back with no issues it was very hard to find a garage nobody really wanted to touch it but I have just had diagnostic codes read and has come back with two fault codes under body control module b106a-11 drivestyle 3 led - circuit short to ground
When you say "smoke test" what was done? If you meant an MOT smoke test that would be with a warm engine and not really tell you about your problem from cold.
Another garage smoke test is introducing smoke to the turbo inlet to check for leaks in the inlet system, this is largely irrelevant when starting an engine.
The one I was referring to was standing at the tail pipe of the exhaust when engine is started from cold to see if white smoke is visible often combined with a smell of diesel.
It is caused by unburnt fuel and can be faulty heater plugs etc. which you mention have been dealt with, but also can be caused by low compression on one or more cylinders of the engine, the other name for a diesel engine is CI which stands for compression ignition, so in simple terms if you have low compression you have poor or no ignition:)
When injectors were out I would have done a compression test as easy then. This would have confirmed or eliminated that side.
Once engine is warmed up then the fuel burns easier and so problem less obvious.
Another indicator of low compression if caused by piston/bore wear can be higher oil consumption, but not always.
Thank you mate I had a smoke test to check for vacuum leaks I've seen a few people mention this issue on Facebook group very strange as it doesn't always do it to be honest with you thanks for the helping advice I think I'm just going to get rid of the car had enough of it enough
