hi
a few weeks ago I asked with regards to wd40 and the ecu I have since had a diagnostic check by my fiat dealer thr code is the same p0747 but on their scanner it states a fuel pressure problem they say its probibly the pump £350 plus fitting Im a bit concerned that if they fit the pump and I still get the light coming on I will not be very happy at the moment Im going around with a scanner on the back seat if I cancel the code it could be ok for a day or a few miles then it comes on again its a manual box.
dave
dave
