P primeruss New member Joined Feb 28, 2005 Messages 179 Points 30 Location Dorchester Dorset Oct 25, 2005 #1 Having just got a Barchetta I was cleaning the muck out from under the seat and found that there is a wire that goes into the seat from the floor underneath. What is it?
Nino_1975 Established member Parked in the garage Joined Jan 27, 2005 Messages 1,185 Points 245 Location Swindon Oct 26, 2005 #2 I think this is your Seat belt system. If you have a crash the seat belt will pull you back into the seat, stop you jurking forward into the window.
Alex Now hacking in PHP Joined Mar 24, 2002 Messages 4,399 Points 734 Location At Home Oct 26, 2005 #3 Yep seatbelt pretentioners, don't disconnect it, because you'll need to reset a light on the dashboard.
OP OP P primeruss New member Joined Feb 28, 2005 Messages 179 Points 30 Location Dorchester Dorset Oct 26, 2005 #4 Ok thanks for that, I have not disconnected them. I work on the basis that if its not broke don't fix it.
Nino_1975 Established member Parked in the garage Joined Jan 27, 2005 Messages 1,185 Points 245 Location Swindon Oct 26, 2005 #5 Yep Alex is right, just looked now, it will set of your Airbag light if you disconnect them. The seat belts and air bags are on the same circuit.,
