Hi all.
My Ducato X250 won't start as the Engine Control Unit has stopped communicating so I think an ECU test and repair is needed.
When the ignition is turned on the VPS warning light comes on continuously (car/padlock symbol) and the cruise control light is on even though the van doesn't have cruise control. Both keys have been tried and the doors will lock/unlock with the remote key fob. My code reader can't link to the ECU but it previously did and can still link to my car's ECU. All fuses are OK, the battery is good and the engine will turn over but not fire.
The problem started after I disconnected the ECU plugs to gain access to the ABS pump (which has been repaired by ECU Testing Ltd) and water got into the ECU electrical socket. Wish I'd taken the nearside headlight out instead!
I sent the ECU to ECU Testing Ltd for a diagnostic check but they can't test it as it has firmware that they haven't previously worked with. ECU part number is 55246596 and is not one that they support.
Does anyone know of someone good at testing ECUs or suggest a better alternative for me to get back on the road as soon as the covid crisis is over?
Thanks in advance
Thanks in advance
