Technical Ecu problem
RCMA
2004 2,3 jtd wont start, gives fault code p0190, i have changed rail pressure sensor, still p0190 present. After that i messured sensor and wire connector with multimeter
pin 1 = 5 volt (ok)
pin 2 = 5 volt (should be 0.3 volt)
Pin 3 = negative ground (ok)
Checked wiring harness from the sensor to the ecu, ok
5 volt present in connector pin 2 when connected and discocceted to the sensor.
Does anybody have diagram for ecu?
Bosch number 0 281 010 488
Pinout for edc15c7 ECU is here wiring diagrams are in the elearn CD.
thanks for the quick reply, yeah i know, but some reason i can't unrar downloaded files
Actually I looked at the diagram and they've omitted the fuel pressure regulator k083, its on pins 90 and 91, brown and orange wires respectively.
