Update.
ran the test/scan option in the
Multiecuscan settings software and it picked up the interface on Com4, just a message re the Latency being too high but that is OK now.
plug it into my vehicle and did the following.
I have used scan in the
Multiecuscan software and it has picked up all the details of my motor, engine body computer dashboard etc, but when I try to connect I get the message ELM327 cannot connect to ecu check serial ports settings etc.
any advice?
regards
Mike
check the
MES supported vehicle list..
SOME say ELM , others ELM C19
Fiat
Ducato (type 250)
Minibus 3.0 16V CNG Magneti Marelli IAW 5SF4 Natural Power Injection (3.0 16V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMOBDKey
Bosch ABS 8 |INFO|DTC|DTC EX|PRM|ACT| KL 12ELM 12OBDKey 12 A3
Bosch ABS 8 ASR |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL 12ELM 12OBDKey 12 A3
Bosch ABS 8 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL 12ELM 12OBDKey 12 A3
TRW Airbag |INFO|DTC| ELMOBDKey A3
TRW Airbag 2 (Ep - PROXI) |INFO|DTC|DTC EX|PRM|ACT| ELMOBDKey
SAGEM Power Steering |INFO|DTC|PRM| KL 12ELM 12OBDKey 12 A3
Service Interval Reset |INFO|ADJ| ELMOBDKey A3
Convergence Lauberhorn C1 (Blue&Me Nav) |INFO|DTC| ELMOBDKey A3
Convergence Marelli/Microsoft (Blue&Me) |INFO|DTC| ELMOBDKey A3
Convergence Marelli/Microsoft C3 (Blue&Me Nav) |INFO|DTC| ELMOBDKey A3
Instrument Panel Marelli |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey A3
Body Computer Marelli (250) |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey A3
CAN Info |INFO| ELMOBDKey A3
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELMOBDKey A3
Denso climate control (Single zone) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey A3
Air suspension control Continental |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey A3
Parking Control BOSCH |INFO|DTC|PRM|ADJ| ELMOBDKey A3
Fiat
Ducato (type 250) Facelift
2.0 Multijet Bosch EDC17C49 CF5/CF5+/EOBD Diesel Injection (2.0) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey
Bosch ABS 9 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey
Bosch ABS 9 ESP |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey
TRW Airbag (Ep - PROXI) |INFO|DTC|DTC EX|PRM|ACT| ELM C19OBDKey C19 A3
TRW Airbag 2 (Ep - PROXI) |INFO|DTC|DTC EX|PRM|ACT| ELM C19OBDKey C19 A3
TRW MY05 Airbag (Ep - PROXI) |INFO|DTC|DTC EX|PRM|ACT| ELM C19OBDKey C19 A3
Service Interval Reset |INFO|ADJ| ELM C19OBDKey C19 A3
Convergence Lauberhorn (Blue&Me) |INFO|DTC|PRM| ELM C19OBDKey C19 A3
Instrument Panel Marelli |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM C19OBDKey C19 A3
Body Computer Marelli (250FL) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM C19OBDKey C19 A3
CAN Info |INFO| ELM C19OBDKey C19 A3
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELM C19OBDKey C19 A3
Denso climate control (Single zone) |INFO|DTC| ELM C19OBDKey C19 A3
Parking Control BOSCH |INFO|DTC|DTC EX|PRM|ADJ| ELM C19OBDKey C19 A3
you MAY need a coloured adaptor cable to read the body computer - often it's just the engine that requires a simple ELM cable.
other components need different wiring set-ups , ABS , Airbag, etc
does it connect to engine ok ? - if you select Engine..
Charlie
