Wiff2110
My 2008 fiat ducato motorhome 2.3Ltr multi jet the clutch pedal stays depressed so unable to select the gear change. The hydraulic oil in the master cylinder is still topped up so there isn’t a leak. So what has gone wrong?
I suspect a "lazy" clutch master cylinder. Confirm with your mechanic before spending. Modern plastic cylinders seem more prone to it.My 2008 fiat ducato motorhome 2.3Ltr multi jet the clutch pedal stays depressed so unable to select the gear change. The hydraulic oil in the master cylinder is still topped up so there isn’t a leak. So what has gone wrong?
If I pull the pedal up when it’s in gear I can drive but as soon as I engage the clutch pedal again it stays down, I’m then committed to using my brakes to stop and stall the engine, clutch pedal remain depressed. It will then lift again by hand but there isn’t any pressure on depressing the pedal it just goes depressed and stays there.I suspect a "lazy" clutch master cylinder. Confirm with your mechanic before spending. Modern plastic cylinders seem more prone to it.
If you reach down and pull the pedal up or pump it a couple of times does it return and feel firm on the down ward stroke like normal.
Just in case it is a lazy pivot arm on the clutch pedal try spraying a bit of WD40 in that area, not so much your foot slips off the brake pedal though.
Try the WD40, but sounds like lazy cylinder.If I pull the pedal up when it’s in gear I can drive but as soon as I engage the clutch pedal again it stays down, I’m then committed to using my brakes to stop and stall the engine, clutch pedal remain depressed. It will then lift again by hand but there isn’t any pressure on depressing the pedal it just goes depressed and stays there.
any idea where I locate this, only my enquiries so far indicates that the slave cylinder is part of the clutch.Try the WD40, but sounds like lazy cylinder.
I don't know for sure on your model, others on Forum can advise better.any idea where I locate this, only my enquiries so far indicates that the slave cylinder is part of the clutch.
