Technical Drivers window fault
BBK
Edinburgh
My drivers window doesnt respond anymore. The switch for the passenger window still operates up and down but i get no response from the drivers side.
Ive checked the fuses and they all work, ive even replaced the whole switch unit with the door handle in with another doblo that works and the drivers window in mine still didnt operate.
I cant hear the motor struggling or even trying so im abit unsure as to what the issue might be. Ive taken the door card off to have a little look and it all looks pretty clean in there. Cant seem to find much about this kind of issue online, any help is appreciated
Model
Fiat Doblo 1.6 Multijet
Year
2017
Mileage
82000
A common fault is the wiring breaking at the door hinge in the thick rubber tube, I had to fit a S/H one on mine as window would work if door half open, bit tricky when driving though.;)
If not you may end up needing a new window motor if window glass has been slow going up for a while motor may have burnt out.
