Yes sounds exactly like mine. Only I just had my clutch and DMF changed. I think it’s a faulty DMF or it hasn’t been fitted correctly if that’s possible. Interesting that you came to DMF as your problem with similar issues. Confirms for me that I am probably right about mine.yes, bit like that. Sounds like it has a prop shaft and it's rattling. if you hold the gear lever as you change gear it feels as though it's in direct contact with the rotating cogs. if you drive with mild acceleration and change gear lightly it's still noticable but only just.
Not really sure about that - maybe if the Golf has a concentric slave - the Pandas don't to my knowledge. The DMF damps rotary forces so wouldn't really expect any additional loads in the axial direction??To widen the DMF issue slightly more, has anyone noticed cars with a suspect DMF issue having clutch master cylinder failure?
The reason I pose this query is daughters 2010 VW Golf 1.6 diesel has had a pattern clutch master cylinder (good quality) and now a slave also for pedal creeping, loss of pressure at a junction waiting for traffic along with pedal sticking down etc.
Although retired after over 55 years in the trade I am always interested to chat with other mechanics and the DMF point was raised that the vibration of the DMF with clutch held down transmitted through to the seals in the master cylinder causing early failure as most are what I feel is inferior plastic cylinders these day.
The other point on the Golf he mentioned is that VW themselves are aware of the problem and supply their clutch master cylinders with the whole pedal assembly as a modified/improved unit.
Any comments?![]()
That model Golf has an external slave cylinder, however to take it to it's logical conclusion one of the symptoms of a failing DPF is a vibration under your foot when touching the clutch pedal, so the theory is that the vibratory load is transmitted back to the seals in the clutch master cylinder etc.Not really sure about that - maybe if the Golf has a concentric slave - the Pandas don't to my knowledge. The DMF damps rotary forces so wouldn't really expect any additional loads in the axial direction??
