DIY rust repairs
DIY rust repairs
oldmanhouse
UK
What's the best method for doing a DIY job on rust bubbles forming around wheel arches, wings and the bonnet?
Of course, the best course is replacement panels or a professional repair but what can you do yourself on a limited budget?
Can you sand down the rust, fill, prime and paint with a pot of touch-up stuff?
Yes, you can do it yourself. Sand down the rust -then use an anti-rust compound to treat the metal - something like 'Kurust':
https://www.ebay.co.uk/sch/i.html?_....TRC2.A0.H0.Xkurust.TRS0&_nkw=kurust&_sacat=0
Then you would prime/fill the area and rub it down again with fine sandpaper.
You would then spray primer onto it, then the spray paint itself. On top of the spray paint you would then have to spray clear lacquer (or use a touch-up pot if available).
A decent car accessory shop will have everything you need. An independent accessory shop would be a better choice.
I'm glad I've just read this. I was going to try and treat the rust in the spare wheel section of my Seicento. But the rust is on both inside and out. So are you saying that treating this with one of the rust remedy products won't work? It is patchy rust, so what if I can expose the patches of rust to bare metal all the way around the rust patch before treating it? Is it still wasting my time?
Andrew
