This is an FYI post.
As per title I've just had to replace my N/S dipped beam headlight bulb after it failed. I had no bulb failure warnings!
Additional tip/info.
Getting to this bulb does NOT require headlamp / bumper removal!
You do however have to:
1) Remove the top cover of the auxiliary fuse box just behind headlamp
2) Lift the plastic clip that holds/positions the top of neck of the windscreen washer bottle and then slide the neck to the left (as viewed from front access position)
3) Bulb tap locates top most
4) Girly
hands preferred. Mike Tyson or Bruno will have problems.
4) Girly
