Technical Diagnosing why aftermarket radio won't power on
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Guff666
I have a 2014 (X290) Ducati campervan. I've just fitted an aftermarket Sony radio, using the fitting kit I bought with the radio.
It's all fitted - except for: the controller for the steering wheel controls - because the 'van doesn't have them; and the reversing camera and leads - ditto.
The radio has no power switch, but it fails to power up when the ignition is turned on. I note that the Odometer display is flashing on the dashboard.
Any clues on how to diagnose the problem?
Gareth
The old sony radio i had has 2 power sockets one main and one backup.
your problem is likely to be the canbus and modules expecting communication from the old radio. You will need to do a Proxi alignmemt. This can be done with Multiecuscan.
see https://www.fiatforum.com/forums/multiecuscan.336/
here members offer the use of thier equipment.
