turn switch to on at the end of the stalk like lights. then when at the speed you want flick it up and should hold speed, flick up to increase speed by 1mph and down the oposite. if you are cruising and put your foot on the brake clutch it will disengage. press the button on the end of the stalk to bring you back up to the speed you were cruising at.
Do you have a separate stalk for cruise control as i haven’t got one.
i was under the impression that cruise control was standard on all S2 Sportings?!?!
ahhhhh maybe so, i can only speak for mark1 GP's
Mine is on an 08 plate if that helps
not really, yours could be mk1 or 2 i belive? anyone else? i would imaging the stalk is in the same place anyway on all models.
remember cruise is an optional extra, you may not have it. its not standard on any Sporting GP.
Standard on Series 2, I got it.... Thought it was +5mph when you tap up - I'm sure I read that in the manual?
