General Crashed but saved
Cornwall
I crashed my loved hgt the other day ? I've just spent a brave bit into fixing her. New wishbone, inner tie rod, outer cv joint, drop links and track rod ends. All nearly fixed just working out how to change the inner tie rod being as its tight to assess! In need of a wing to as the wheel done a good job to it!!
Subframe missing some paint? Better apply some zinc and hammerite.
I hit a curb on a roundabout and the wishbone and cv joint took the impact! Wishbone broke into 2 and the cv joint bearings where crushed! Neverth when I replace the wishbone I sprayed hammerite under body spray over the paintless areas ��
Wow, scary one! i still wouldn't expect the wishbone to give way!
I know it sounds weird, but it's probably lucky you hit the curb and crash it where and when you did, imagine catching a pothole or something on a country lane at 60mph only for it to snap? think i'd be changing the other side too as a precaution!
Glad the damage wasn't too bad and most importantly of all, you were ok :)
