Hey guys, does anyone use or know of Corrosion X, was thinking of using this to prevent my exhaust from rusting. Or is it too harsh for our cars? If so, what do other people use?
Thanks in advance
Thanks in advance
I was always under the impression that car exhaust systems rusted from the inside out.
Thanks in advance![]()
lack of use / short journeys will fill the rear section of ANY exhaust with water , so it'll rust from the inside out.![]()
TBH I'd NEVER considered any form of treatment on a car exhaust
I suppose I should be more specific, I was meaning more for the exhaust tip, the visible part, just for appearance reasons really I guess. Or is the tip only chrome plated?
Sorry about that, thanks![]()
You're probably as well off using Preparation H on your exhaust instead of Corrosion X.
The tip is just a chrome plated tack welded cosmetic add-on, and not particularly good chrome at that. It's more prone to rusting than it should be.
Keep it clean and use a good quality wax polish or even a light coating of WD40 rubbed well in.
Whatever you use, you'll likely have to apply it frequently.
I was way too young and unknowledgable to understand that without the use of Google haha :')You're probably as well off using Preparation H on your exhaust instead of Corrosion X.
