M
Mike
Hi everyone, its been a while, been getting settled into the new job and all that.
Just recently I have a new problem with my Bravo.
When I push the clutch pedal in, there is a cracking sound when the pedal is just about fully pressed. More so noticeable when the engine is turned off and you push the clutch pedal (its stiff as hell, and spongy, then the crack which is once per pedal press but not everytime.)
I have managed to pin point the sound under the bonnet. I have removed the battery tray to get to the slave cyclinder. There is no sign of this leaking but the rubber gaitor has split in to two pieces.
The problem now is that I can't work out if it is a problem related to the slave cylinder, or the release arm on the transmission (or worse, as this will link to things inside the transmission).
Has anyone ever experienced a problem like this? any help would be gratly appreciated.
Mike
Mike
