Technical Cinquecento gear box strip and rebuild
Rob25040
Kent
Hi could anyone please advise?. I have removed the gear box from my son 1995 Cinquecento because he snapped a bolt while replacing the inner CV boot and I couldn't access to remove it because of the sump. Whilst it is out we thought I would be with sorting the 3rd gear synchro. As far as I can tell I have removed everything needed to split the cases but can't seem to get more than 3/4 separation and the shafts don't seem to want to come out from the bearings. Does anyone have a strip down procedure for this.
TIA ROB
Year
1995
TIA ROB
Don't know specifically about your model, but generally the "lay gears" need dropping out of the way to allow full stripping of a gearbox on many vehicles.
I assume selectors are not stopping you?
Not sure if it's the same 'box, does this help?
If it is, I would consider replacing the input shaft bearing and seal, a known weak point on these transmissions. Certainly check for play in the bearing. And maybe driveshaft seals too whilst the box is off the car.
