Technical Changed locks immobiliser problem?
alfieallen29
Essex
I have changed my ignition barrel, transponder collar, ECU, BSI and yet it is still coming up with 'code' on the dash? Any idea what next...
is body computer clipped into fuse box securely?
its easy for it to not be
are you sure you not been sold a pup too?
of course the obvious that the earth on the throttle body is connected and the ecu is tight to give a good connection on the throttle body too
I have also read up that the ECU may be storing a code to immobilise it I'm I wrong?
